What????mmm? Less engine power on newer car
izzy96
Post by izzy96 »
Can some one tell my why the 1st gen gt produces more horsepower than the second??? #hatting lol
SeattleJeremy
Re: What????mmm? Less engine power on newer car
Post by SeattleJeremy »
izzy96 wrote:Can some one tell my why the 1st gen gt produces more horsepower than the second??? #hatting lol
The first gen GT had a VVTL-i engine, which is like Honda's VTEC technology.
http://en.wikipedia.org/wiki/VVT-i" onclick="window.open(this.href);return false;
The second gen GT uses a Camry motor, which makes more torque across the entire rev-range, and more HP from 1000-rpm to when Lift kicks in, but does produce less overall HP.
izzy96
Post by izzy96 »
So what's the 2nd gen gt's engine name.. And I know that there is probably already a hole forum on this but any cheap quick easy mods to get some extra hp on it?
kumquat
Post by kumquat »
The 2nd gen GT uses the 2AZ-FE.
The 1st gen uses the 2ZZ-GE.
The 2 in each means 2nd generation of that engine. The AZ/ZZ refers tot he engine family. The "F" means narrow-angle valves (for fuel efficiency) while the G means wide-angle valves (for performance). E just means electronic fuel injection.
thebarber
Post by thebarber »
either way, gen1's are quicker
...gen1 was quicker, though you had to keep the revs up to eleventeen thousand RPM's to get anything out of it. And ZOMG, PREMIUM FUEL! :lol:
It was quite dramatic when lift kicked in, though personally I'd appreciate more usable torque available elsewhere.
izzy96 wrote:And I know that there is probably already a hole forum on this but any cheap quick easy mods to get some extra hp on it?
Not too many 2009-2010 Vibe GT owners here doing much performance-wise beyond the K&N Typhoon intake. This member had quite a bit done to his engine, but he no longer owns it and hasn't posted in over a year.
