I installed the remote starter last fall, after a bit of frustration that I paid $120 and found out the trunk(glass hatch) release supposedly doesn't work for the 08 vibe I figured I'd buy a relay and make it work.
so the symptoms were as follows:
when i pressed the unlock on the bulldog fob it only unlocked the drivers door(compared to the factory fob that unlock all doors if pressed twice quickly).
when i used the hatch release it would also start the car
as the tach would rev higher i could hear both relays going off in line w/ the rev. (I'm probably wrong, but i think this may be b/c i need to install the relay 12 volt connection into the main box somehow or splice in on the other side)
Thanks for your help!
