Hey yall, a few months back installed a ram air intake. I modified the airbox and punched a hole in the hood... got a sweet scoop. Will post pics when I get the chance (cost me $10 for a intake hose and $40 for the k&n lifetime filter, a lot cheaper than some of the CAIs ppl are buying).
Oh BTW sound is sweeet. Like a grumpy roar between 3-5k. If you listen closely there is also a nice whine when you stomp it.
Anyways sometimes when the vibe is idling I can hear a slight knocking sound. It will increase with the car rpm if the idle increases from 800 to 1000 as it sometimes does. You can also hear it while driving below 2k in the lower gears. It is not present on hard/normal acceleration, and was not present before my airbox mod. Only when you are idle or near idle and then only sometimes, usually after it is warm. The sound is coming from the airbox, not a rattle though something inside the engine is making it.
Is this just the DE-restricted vibe idle noise? Some other forums say they get similar noises when installing a CAI or RAI. Why would it come and go?
I recently got worried about the noise while reading up about oil entering intake from pcv valve and causing knocking. Doesn't sound like pre-ign or det, but I worry a lot so idk.
Any thoughts?
