Ram Air Intake Noise
GTwannabe
Post by GTwannabe »
Hey yall, a few months back installed a ram air intake. I modified the airbox and punched a hole in the hood... got a sweet scoop. Will post pics when I get the chance (cost me $10 for a intake hose and $40 for the k&n lifetime filter, a lot cheaper than some of the CAIs ppl are buying).
Oh BTW sound is sweeet. Like a grumpy roar between 3-5k. If you listen closely there is also a nice whine when you stomp it.
Anyways sometimes when the vibe is idling I can hear a slight knocking sound. It will increase with the car rpm if the idle increases from 800 to 1000 as it sometimes does. You can also hear it while driving below 2k in the lower gears. It is not present on hard/normal acceleration, and was not present before my airbox mod. Only when you are idle or near idle and then only sometimes, usually after it is warm. The sound is coming from the airbox, not a rattle though something inside the engine is making it.
Is this just the DE-restricted vibe idle noise? Some other forums say they get similar noises when installing a CAI or RAI. Why would it come and go?
I recently got worried about the noise while reading up about oil entering intake from pcv valve and causing knocking. Doesn't sound like pre-ign or det, but I worry a lot so idk.
Any thoughts?
Kendrick Lamar agrees... Keep your Vibe alive and well...
http://www.youtube.com/watch?v=GF8aaTu2kg0
beemerphile1
Re: Ram Air Intake Noise
Post by beemerphile1 »
You might want to add some more info like what engine, any other mods, how many miles, what year, etc.
Water boy
Post by Water boy »
And a sound clip.
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
Doug14
Post by Doug14 »
indeed, pics and vid/soundclip
GTwannabe
Post by GTwannabe »
I have an 07 1zz engine with 115k miles.
The engine has needed no work besides fluid/plug changes.
I was wondering if It could be the PCV valve, but not really sure.
Sorry can't upload sound.
GTwannabe
Post by GTwannabe »
Oh and I have been running my air filter for 5k miles now with the noise begining with the swap. The CAI gets air through a scoop and some holes cut through the hood. Using square stock replacement K&N. The only thing between the throttle body and filter is a 3 in pipe, mass air sensor, and PCV valve hose. No additional screens. The entire upper half of the filter is directly exposed to the air (wether or not ram air gets to it in meaningful amounts is another question). This set up should be giving me a similar airflow to the round CAI people use.
Doug14
Post by Doug14 »
You could always try cleaning the maf and throttle body, and cleaning or replacing pcv valve. Not sure if original maf tube size is 2.75" or 3" but could be an issue
Nasmfell
Post by Nasmfell »
GTwannabe wrote:I have an 07 1zz engine with 115k miles.
Have you had the valve clearances checked at the 60K interval?
Water boy
Post by Water boy »
Hummmm....
Did I forget to get this done 50,000 miles ago?
I've not read too much here about people having the valves done at any mileage.
2008
70,395 Battery
Doug14
Post by Doug14 »
It says to have them checked, but many members have not had issues. I wouldn't bother with that unless there is other top end work that needs to be done.
