Let's start with the positive.. I purchased my 05 vibe base last year.. It's been a great vehicle. I installed a kick A## sound system, tinted my windows, and cleaned the crap out of it. I am tickled pink with my little car that averages 30 miles a gallon!!! Only problem i've had with it so far was a door check and broken fog lights.. Fixed em both and at a decent price..
Now the negative.. My other vehicle is a 2000 ponitac montana.. this little turd burner is misbehaving. It eats fuel pumps for lunch, and as such always displays a p0131 diag code.. This particular diag code has been present for a few years and is likely caused by my unwillingness to climb back underneath and ensure my evap lines are tight to the char can.. In any case.. one day a few weeks ago I decided it was a good idea to try and fix it. I tightened the lines and replaced both oxygen sensors.. In trying to get to the top sensor, i was tasked with rocking the motor forward to get to it. After that failed to provide adequate space, i replaced the sensor from underneath and remounted my motor to where it belonged.. After I did this the motor threw alot of different codes.. misfire codes, mas airflow codes, lean codes.. blah blah blah.. I went through all the wiring, connectors,, vacuum hoses etc etc.. I resolved MOST of my problems but a persistent issue is still present..
My persistent issue is that of a rough idle in park or neutral. It's so bad the motor will stall.. This happens only when brought up to temp, and only intermittently.. the codes i get are my forever p0131 and a NEW one P0171.. I could care less about the P0131 as it has "always" been present but the "too lean" code is kicking my trash.. I believe this code to be a symptom of my rough idle and stall...
Knowing cars fairly well, and being cheap.. I figure i could resolve this issue without having to take it to a mechanic/dealer.. Now I'm not so sure.. I have replaced practically every vacuum hose known to man.NO GO ... I thought it to be a mass air flow sensor as when unplugged, the idle evens out and does not stall. I replaced the mass air flow sensor.. NO GO my new friend P0171 comes up still. My motor continues to stall in at idle in park/neutral.. Most forums are telling me it's a vacuum leak.. I used a can of carb cleaner and drenched all my hoses while the motor was running.. This included spraying around the plenum/intake manifold. This "test" yielded no results.. the motor in its intermittently working state did not respond to my assault..
so.. not vacuum leak (or intermittent vacuum leak?).. not mass airflow sensor... has to be fuel related right? clogged ports.. slow painful death of the fuel pump? I dumped a bunch of injector cleaner in my tank, and have almost wen through the tank now.. issue still remains but once I find a 90 degree adapter i can test this theory.. but the adapter appears to be quite the elusive creature..
Now for the question part... Does anyone know if an ac quick connect will fit and function on a fuel rail? I know the rail is a screw on type of fitting but one can't be certain unless tested right? Anyone else own a montana or other pontiac/gm product with a 3.4L motor with similar issues they have resolved with some magic and wisdom?
I am so glad the vibe does NOT have a gm motor in it.. I would not have purchased it if it had.. gm isn't all that bad (no really it is..) I just don't like working on vans.. Can't get to the back of the motor very easily if at all..
on a second thought.. could the oxygen sensor be causing the P0171? any way to really test this without a fancy reader? Did i mention i hate cars.. except my vibe of course
