Ebays 03-06 matrix xr compatible to vibe 08?
keko
Post by keko »
Was looking through ebay and saw a CAI for matrix xr 03-06/corolla 03-04. Will the fit a Vibe 2008?
EricTMah
Re: Ebays 03-06 matrix xr compatible to vibe 08?
Post by EricTMah »
Not a 100% sure about the base matrix/corolla/vibe. But I know the 03-04 XRS won't work on the 05+ XRS cause of the air injection tubes
Salsa Guy
Post by Salsa Guy »
I'm assuming you have a 1zz engine. It will work but you may need to add a breather filter to hose that comes out of the top front of the engine and fits into the stock air tube before the TB. $10 part at autozone. Look for a pic of my engine it's shows what I'm talking about.
keko
Post by keko »
Yes i have the 1zz, I've read that you can add another piece of hoses to make it fit over the air tube.
@Salsaguy cant see any pic!
Salsa Guy
Post by Salsa Guy »
Post a link for the SRI. Also be prepared to replace the filter. As far as a pic do some searches on Genvibe. Also PLEASE remove the negative battery cable first and makeit the last thing you put back on. Could save you $100 and a lot of headaches.
Checkout this thread for a PIC
viewtopic.php?f=12&t=36953&p=414279#p414279" onclick="window.open(this.href);return false;
keko
Post by keko »
http://www.ebay.com/itm/0203-Impreza-WR ... 0926307004" onclick="window.open(this.href);return false;
http://www.ebay.com/itm/0308-Toyota-Mat ... 0897265610" onclick="window.open(this.href);return false;
http://www.ebay.com/itm/0306-MATRIX-XR- ... 0629262515" onclick="window.open(this.href);return false;
Salsa Guy
Post by Salsa Guy »
I added a like to my last post.
You realize you won't gain much but some noise. A K&N drop in will gain the same results. I have an ebay SRI but have an AEM Dry Flo with it.
shaeet
Post by shaeet »
EricTMah wrote:Not a 100% sure about the base matrix/corolla/vibe. But I know the 03-04 XRS won't work on the 05+ XRS cause of the air injection tubes
The 04's had air injection also, 03's are the only XRS without the stupid air injection pump.
The 03-08 1ZZ powered vibe/matrix shouldn't be any different as far as the intake. Nothing major changed other than drive by wire in 05+ models and that has nothing to do with the intake.
04 XRS 2ZZ-GE: Injen CAI, hotchkis sways, sportlines on gr2's, brz rims
(Soon For Sale) 05 Vibe 1ZZ auto, 02 WRX Stage 4, 09 VW Jetta Sportwagen TDI
