I'm assuming you have a 1zz engine. It will work but you may need to add a breather filter to hose that comes out of the top front of the engine and fits into the stock air tube before the TB. $10 part at autozone. Look for a pic of my engine it's shows what I'm talking about.
Post a link for the SRI. Also be prepared to replace the filter. As far as a pic do some searches on Genvibe. Also PLEASE remove the negative battery cable first and makeit the last thing you put back on. Could save you $100 and a lot of headaches.
You realize you won't gain much but some noise. A K&N drop in will gain the same results. I have an ebay SRI but have an AEM Dry Flo with it.
EricTMah wrote:Not a 100% sure about the base matrix/corolla/vibe. But I know the 03-04 XRS won't work on the 05+ XRS cause of the air injection tubes
The 04's had air injection also, 03's are the only XRS without the stupid air injection pump.
The 03-08 1ZZ powered vibe/matrix shouldn't be any different as far as the intake. Nothing major changed other than drive by wire in 05+ models and that has nothing to do with the intake.
