Today, I found my passenger side fog light to be broken. It looks like something hit it, maybe? I'm not entirely sure.
Can I fix it? Replace it, preferably on the cheap because I don't have any money?
Thanks, I'll have a look around here.Chiadog wrote:I found a replacement fog light from my local Junk Yard when I broke one!
good luck,
chiadog
Once you get under the bumper with a flashlight it all becomes clear.03VIBEswfl wrote:Any tips/how-to's on replacing the whole foglight assembly?
How easy is it to do? I'm not the most handy guy around, I'm likely to cut off a finger with a spoon. (And yet they let me drag on the tracks?)jjminch wrote:On my vibe both lenses were broken out badly. The reflector bowls were also rotted out and not really chrome anymore.
Bought a sheet of lexan plastic from Home Depot. Traced out the housings on it, cut and sanded The edges. Then I removed the old glass, scraped out old silicon, painted the insides silver with lots of clear, and silicones the lexan lenses on.
Doesn't look as good as OEM, but for 12 bucks or whatever it'll do.
That seems easy enough, can I get all of this stuff at local places?jjminch wrote:Here is a how to for an acura. Now the vibe foglight doesn't have a trim ring that goes around like this one. That is the big difference. http://www.acuraworld.com/forums/f27/di ... fix-69762/" onclick="window.open(this.href);return false;
-Remove foglight assembly.
-Bake in oven for 7 mins at 200 degrees
-Remove old lens and scrape out silicon
-Trace foglight on lexan, then cut lexan with skill saw
-Sand down edges to get a nice fit
-Silicon the heck out of the channel on the foglight.
-Mount lexan and clamp it to housing. Let dry for a few hours.
Cool, I'll have to wait until it isn't over 100 degrees outside so I can work on it!jjminch wrote:Home Depot or lowes sells sheets of lexan. Walmart or auto store for silicon.
I know this is an old post and maybe you already fixed it, but I have a brand new driver-side assembly for sale: viewtopic.php?f=46&t=41906" onclick="window.open(this.href);return false;tkenway wrote:Cool, I'll have to wait until it isn't over 100 degrees outside so I can work on it!jjminch wrote:Home Depot or lowes sells sheets of lexan. Walmart or auto store for silicon.
