Here is my two year update.
The Vibe is still running great. Today I replaced the 215/55/18 Hankook tires with 225/40 Goodyear Eagle F1 All seasons. I bought the Eagles for my ION Redline but then decided to put them on the Vibe. The 215/55s were too tall. I don't recommend anyone run them. I installed 5mm spacers and kept the air pressure at 44psi but I was still not able to turn the wheel all the way to either side without the tire hitting some where in the fender. Got sick of dealing with... And the Hankook tires performed fairly well the first winter but really sucked this past winter. I guess that is what you get with a tire that has a 100k mile warrenty. The tires still have a ton of tread on them so I should be able to sell them pretty easy.
So we bought the car with just under 36,000 and it now has 69,800. The shop that changed my tires said I needed new brakes and rotors and they would gladly do it for $600. Yeah "okay", not. I pulled the wheels off and sure enough all the pads where pretty well worn. Rotors looked fine so I took them to O'Reilly's to get turned. The guy behind the counter said there was plenty of metal left. Brakes are a nice and easy job on this car.
With new pads I won't have much more then $100 into the job.
On an unrelated note, the ABS light has been turning on and off for the last couple of months. A quick search indicated the problem is most likely a bad ABS sensor which might be covered by the powertrain warranty. I need to do a little more digging...
I installed a trailer package last summer which we use to hall wood and gas up to the lake.
Overall we have been very happy with the Vibe. I hope the next 30,000 miles are as enjoyable as the last!
