Hey guys, new to the VibeNation, just curious if anyone knows of any brand of lowering spring manufacture that sells springs for a 2010 Pontiac Vibe/2010 Toyota Matrix? Also do you think toyota springs will fit. looking for a 1.5 drop. Thank guys.
If your 2010 Vibe is either a 1.8L or 2.4L Base, you can use the TRD springs which will give you a 0.5" drop in the front and a 1.5" drop in the rear. If your 2010 Vibe is an AWD or GT, you will have to use springs made for the older Vibe/Matrix. For more information on lowering, check out the Matrix Owners Forum.
I can't tell you what kind of drop you'll get from Canuck springs, but they should work fine. One poster here did have them. Mine is lowered about 2" on Tein H-Tech springs that are a listed fit for the 1st gen Vibe. When I was looking for springs nothing was spec'd for the 2009-10, but several people have used the 1st gen springs with no issues - it just seems to drop the 2nd gen cars a little bit more (like maybe 1/4 - 1/2 inch).
