2010 base intermittent wiper relay noise - where are they?
tonycheung
Post by tonycheung »
Hi,
There is a noticeable "click" sound when intermittent wiper is engaged and I found it is pretty annoying. I am quite sensitive to noise.
I guess it is from the relay. Is there any schematic or picture showing where the relay box is, and which relay it is?
I plan to place some kind of foam over the relay or the whole box to isolate the noise...
Thank you,
Tony
Re: 2010 base intermittent wiper relay noise - where are the
Tony. I don't know if any of the attached pics will help you or not BUT after studying and reading all about the wiper system, I'm a bit baffled myself. Somewhere there are relays to control it BUT now I'm not even sure exactly where they are located.
Fuse block I/P location under drivers side dash
Location of the IG1 relay on the fuse block
finally the complete wiring schematic of the front wipers (according to Helm ) seems there are some relays missing ???
It can only help. Not sure now that I confused myself :? Good luck!
2014 Silverado, 2004 Vibe GT
tonycheung
Thank you so much! I have to say that I am not an electrician, and get confused.... :cry:
