Can we fit oem 17 inch whell of vibe 2009 on a 2003 vibe
drago
Post by drago »
Hi everyone,
does someone try or know if we can put 17 inch oem 5 spokes of a 2009 pontiac vibe on a 2003-2006 vibe fwd. Does the bolt patern is the same.
I saw a great deal in my area and i'll buy it if it fits.
Thanks in advance
Re: Can we fit oem 17 inch whell of vibe 2009 on a 2003 vibe
If the 17 inch rim was off a 1.8L 2009 Vibe, then yes. If the rim was from a vibe with the 2.4, then no.
The bolt pattern for the 09-10 2.4L Vibes is 5-114 whereas the pattern for 03-10 1.8L Vibes is 5-100.
I believe - and someone feel free to correct me if I'm wrong -- the larger wheels have a different bolt pattern. I think only the base wheels (steel) on the '09-10 had the same bolt pattern as the 2003-2008. I'm sure someone can confirm this...
EDIT: What star deceiver said... :)
drago
Post by drago »
Hummm interesting.
Thanks for the quick answer,
i will have ta ask to the guy what model of vibe he had (he told me that his car has been stolen so it's why he put the wheels for sale...)
So you are 100% sure of that. Because if you are i'll will pass my turn for that deal i think so.
Thank you star deceiver
Yes, they are correct. The 2009-2010 OEM Pontiac alloy wheels will not fit the earlier Vibes. I wish they did as I bet the wheels would look nice on the earlier models.
star_deceiver wrote:If the 17 inch rim was off a 1.8L 2009 Vibe, then yes. If the rim was from a vibe with the 2.4, then no.
The only OEM wheels that came on 2009-2010 1.8Ls were 16" steel wheels with wheel covers. 2.4Ls came with all the other wheels (16 steel wheels [with different wheel covers], 17s and 18s).
And yes, just as everyone else has said...
All 2003-2008 Vibes & 2009-2010 1.8L Vibes = 5x100 bolt pattern
2009-2010 2.4L Vibes = 5x114.3 bolt pattern
drago
Post by drago »
Thanks everyone for your explications.
drago wrote:Thanks everyone for your explications.
You're very welcome! That's what we're here for ;)!
Capt.Vibe
Post by Capt.Vibe »
This man knows his Vibes. Kudos to you, that is 100% accurate and correct. I also wished the 09-10 Vibe 17's or 18's would fit on the base 1.8Ls. :( Those wheels are beautiful.
2010 Red Hot Metallic 1SA
Capt.Vibe wrote: ^^^^
Thanks, but I'm a girl ;)!
Not to worry though... there's plenty of nice aftermarket rims out there!!!
Capt.Vibe
Post by Capt.Vibe »
wow...All the more impressive. :shock:
:lol: Thanks!
PlatinumVibe08
Post by PlatinumVibe08 »
Snag some 17" alloy Scion tC wheels for your 2003-2008 Vibe. They're affordable and look great! ;)
2006 Lexus SC430 White Gold Crystal
2010 Lexus RX350 Matador Red Mica
2013 Lexus CT200h Starfire Pearl
PlatinumVibe08 wrote:Snag some 17" alloy Scion tC wheels for your 2003-2008 Vibe. They're affordable and look great! ;)
I find it interesting that the newest tCs now share their bolt pattern (5x114.3) with the 2009-2010 2.4L Vibes :P. I see a white one on my way home from work almost everyday and it has OEM gunmetal wheels on it that are pretty sharp looking.
