The only OEM wheels that came on 2009-2010 1.8Ls were 16" steel wheels with wheel covers. 2.4Ls came with all the other wheels (16 steel wheels [with different wheel covers], 17s and 18s).star_deceiver wrote:If the 17 inch rim was off a 1.8L 2009 Vibe, then yes. If the rim was from a vibe with the 2.4, then no.
You're very welcome! That's what we're here fordrago wrote:Thanks everyone for your explications.
^^^^vibenvy wrote:The only OEM wheels that came on 2009-2010 1.8Ls were 16" steel wheels with wheel covers. 2.4Ls came with all the other wheels (16 steel wheels [with different wheel covers], 17s and 18s).star_deceiver wrote:If the 17 inch rim was off a 1.8L 2009 Vibe, then yes. If the rim was from a vibe with the 2.4, then no.
And yes, just as everyone else has said...
All 2003-2008 Vibes & 2009-2010 1.8L Vibes = 5x100 bolt pattern
2009-2010 2.4L Vibes = 5x114.3 bolt pattern
Thanks, but I'm a girlCapt.Vibe wrote: ^^^^
This man knows his Vibes. Kudos to you, that is 100% accurate and correct. I also wished the 09-10 Vibe 17's or 18's would fit on the base 1.8Ls.Those wheels are beautiful.
vibenvy wrote:Thanks, but I'm a girlCapt.Vibe wrote: ^^^^
Capt.Vibe wrote:wow...All the more impressive.vibenvy wrote:Thanks, but I'm a girlCapt.Vibe wrote: ^^^^
I find it interesting that the newest tCs now share their bolt pattern (5x114.3) with the 2009-2010 2.4L VibesPlatinumVibe08 wrote:Snag some 17" alloy Scion tC wheels for your 2003-2008 Vibe. They're affordable and look great!
