Hi there,
I'm a long-time lurker; I love the forums here.  The community is great, and I thought I'd finally jump in.  I have had my 2004 Vibe GT for a little over a year, and a good 18,000 miles (170,000 miles on the OD).
Anyway, the clutch was (typically) never very solid when I got the car - and after I let my brother drive it home one day he smoked it - so now I'm getting it replaced with the OE replacement Exedy clutch.  Also, because I'm having an independent mechanic do it in a situation where he doesn't have any extra time to get the flywheel machined, I decided to get a new flywheel - and upgrade while I'm at it.  I got one of the F1 Racing chromoly flywheels based on the good reviews I've seen for it - and yes, it is CNC machined very nicely with the exception of a couple of burrs that weren't cleaned up.
There is one thing I've read about the F1 Racing flywheels, though - that the pressure plate tapped holes aren't always the same thread as stock.  I checked the holes on the F1 chromoly flywheel - they're M8-1.25.  Can anyone tell me if that's what the stock bolts are on the 2zz?  I suspect they may be M8-1.0 threads, but I have no way of finding out without either ordering replacements that might not work and I probably wouldn't need otherwise, or waiting until the clutch is out (which I can't do given my time constraints).  The stock part no. should be 90119-08079 from Toyota.
Thanks - and glad to be here!
Ben
