Hi guys and gals. I have an 05 Vibe GT and have a slight issue. I have intermittent power issues when taken off from a standstill and also when trying to accelerate on the freeway from about 3000prm. the odd thing about the freeway issue is when I put the pedal to WOT the vehicle takes off without a problem. A tech friend of mine mentioned the MAP sensor change after checking the car out with tech2 so I've changed that out. The issue from stand still is pretty much the same as at 3 except absolutely nothing until you really hit the throttle. Any recommendations?
Thanks.
