While it was there they found that the battery was leaking some acid and ate through the negative cable. They ended up replacing the battery and changing the entire engine harness under warranty which took them three days since they didn't have it in stock. I had a loaner for that time so I think they rushed this and didn't fix the washer as they should have.
