Hey, I'm changing my factory horn to Hella horns. I got everything wired and bolted in, but need to change the relay. Does anyone know where the horn relay is located on an 09 vibe??
Thanks for anyones help.
I was thinking about doing this mod to my 09 Vibe also. I'll assume you keep the one OEM relay for one of the Hella horns, THEN add another relay for the second horn. This is due to the OEM relay not being able to handle the current draw of TWO horns? Explain if possiblekeithvibe wrote: you should be adding another relay.
I second that, it's worth taking the extra time to use the relay.keithvibe wrote: I recommend that if you have the time to wire them with the relay, do it.
