Cleaning the gauge cluster?
Toasted7
Post by Toasted7 »
What do you use and how do you clean the faces on the guage cluster? (ie. speedometer, tach, etc.)
VMFIC of Cincinnati Scikotics Cincinnati Scikotics sponsored by: KerryScion.com My other ride is your mom
ragingfish
Re: Cleaning the gauge cluster? (Toasted7)
Post by ragingfish »
I just use glass cleaner, but I'm looking to get Mother's Plastic Polish which supposedly is much better for the purpose...
2009 PONTIAC G8
engine1
Re: Cleaning the gauge cluster? (ragingfish)
Post by engine1 »
And get one of those micro fibre cloths, I tried diapers, cheese cloth, that soft polishing cloth GM gives you. Every one left scratches! And pull the facia off its so much easier to clean then you don't get that little dust halo around the edge of each guage!
Abyss Monotone Power Package All exterior lights upgraded to Piaa 60 Series Flowmaster, K&N Typhoon Autometer liquid filled oil pressure guage 5% Tint on all five rear windows Hurst Pistol Grip shifter, Piaa Sports Horns
ragingfish
Re: Cleaning the gauge cluster? (engine1)
quote:And pull the facia off its so much easier to clean then you don't get that little dust halo around the edge of each guage!Yep...always do!
2009 PONTIAC G8
Toasted7
Post by Toasted7 »
quote:And pull the facia off its so much easier to clean then you don't get that little dust halo around the edge of each guage!Yep...always do!Do wha? Please tell... how do I get the guage cluster facia off to clean behind it? Details, cause I don't want to break anything.
ragingfish
Quite simple. Just lower the steering wheel all the way, grasp the circles on each end, and pull forward. Comes right off. Then, to put it back on, just make sure you thread the odometer button through, and push back until it snaps in place!
2009 PONTIAC G8
Toasted7
Post by Toasted7 »
That easy? The whole cluster comes off, not just the chrome right? If it is really that simple, that will make cleaning a whole lot easier. Now if I could just figure out what to use that won't leave scratches, then I will be in business.
ragingfish
Yeah, whole ringset comes off...I'm gonna track down that plastic polish and let you know how it works out...
2009 PONTIAC G8
Toasted7
Post by Toasted7 »
Let me know when you find it and how it works... as for me, I'm going to try to get that cluster panel off, just to see if it is really that easy to remove.
ragingfish
Just ordered Mothers Plastic Polish online...should have next week sometime...will let y'all know how it works out. It's supposed to be good for both the gauge cluster as well as the headlight lenses...Also ordered Mothers California Gold Touch Up Kit, which you use in conjunction with touch-up paint, and supposedly does wonders to fill in scratches...will also let y'all know how that one works out...
2009 PONTIAC G8
NSimkins
Global Moderator
Post by NSimkins »
quote:Let me know when you find it and how it works... as for me, I'm going to try to get that cluster panel off, just to see if it is really that easy to remove.I have pictures of the gauge rings removed in this older thread. That should help you get an idea on how to remove.http://forums.genvibe.com/zerothread?id=396
meathead333
Re: Cleaning the gauge cluster? (NSimkins)
Post by meathead333 »
i cleaned it once real well with glass cleaner. now i just a swifter duster, it picks up all the dust and stuff real well.
My myspace.com profile My 73' Bronco Cardomain page
ragingfish
2009 PONTIAC G8
champcaracing
Post by champcaracing »
pull the bezal off, then use 3m hand glaze, works great!!!!
03 toyota matrix XRS 6 speed, lunar mist,factory 17 inch rims w/firehawks- summer tiresfactory 16 inch rims with dunlops- winter tirestrd sway bars, trd strut brace, trd sport muffler,trd quick shifter,trd cold air intake, toyota tundra dual horns,factory toyota wing from toyota canada, both front door handle modsNEW pioneer AVIC-D1 nav unit, XM radio installed
Stang2Vibe
Re: Cleaning the gauge cluster? (champcaracing)
Post by Stang2Vibe »
I suggest just wiping it clean with a lens cloth. I have one made by 3M that I use on my glasses. I got to thinking one day while cleaning the car and found that it works well. Everything else scratches the plastic. And a big thank-you to those who discovered how to pull the gauge cluster apart, it will make cleaning a whole lot easier! Now if only I can find some white faced aftermarket gauges...
