And get one of those micro fibre cloths, I tried diapers, cheese cloth, that soft polishing cloth GM gives you. Every one left scratches! And pull the facia off its so much easier to clean then you don't get that little dust halo around the edge of each guage!
Abyss Monotone Power Package All exterior lights upgraded to Piaa 60 Series Flowmaster, K&N Typhoon Autometer liquid filled oil pressure guage 5% Tint on all five rear windows Hurst Pistol Grip shifter, Piaa Sports Horns
quote:And pull the facia off its so much easier to clean then you don't get that little dust halo around the edge of each guage!Yep...always do!Do wha? Please tell... how do I get the guage cluster facia off to clean behind it? Details, cause I don't want to break anything.
Quite simple. Just lower the steering wheel all the way, grasp the circles on each end, and pull forward. Comes right off. Then, to put it back on, just make sure you thread the odometer button through, and push back until it snaps in place!
That easy? The whole cluster comes off, not just the chrome right? If it is really that simple, that will make cleaning a whole lot easier. Now if I could just figure out what to use that won't leave scratches, then I will be in business.
Let me know when you find it and how it works... as for me, I'm going to try to get that cluster panel off, just to see if it is really that easy to remove.
Just ordered Mothers Plastic Polish online...should have next week sometime...will let y'all know how it works out. It's supposed to be good for both the gauge cluster as well as the headlight lenses...Also ordered Mothers California Gold Touch Up Kit, which you use in conjunction with touch-up paint, and supposedly does wonders to fill in scratches...will also let y'all know how that one works out...
quote:Let me know when you find it and how it works... as for me, I'm going to try to get that cluster panel off, just to see if it is really that easy to remove.I have pictures of the gauge rings removed in this older thread. That should help you get an idea on how to remove.http://forums.genvibe.com/zerothread?id=396
pull the bezal off, then use 3m hand glaze, works great!!!!
03 toyota matrix XRS 6 speed, lunar mist,factory 17 inch rims w/firehawks- summer tiresfactory 16 inch rims with dunlops- winter tirestrd sway bars, trd strut brace, trd sport muffler,trd quick shifter,trd cold air intake, toyota tundra dual horns,factory toyota wing from toyota canada, both front door handle modsNEW pioneer AVIC-D1 nav unit, XM radio installed
I suggest just wiping it clean with a lens cloth. I have one made by 3M that I use on my glasses. I got to thinking one day while cleaning the car and found that it works well. Everything else scratches the plastic. And a big thank-you to those who discovered how to pull the gauge cluster apart, it will make cleaning a whole lot easier! Now if only I can find some white faced aftermarket gauges...
