Hi guys, recently my radiator fan stopped working. As per the usual, I check the Fuses. The RDI Fan fuse under the hood
is okay. I removed the fuse, and tested the fuse port for the fan with a tester, and there is current. When I remove
the connection from the fan motor, and test for current, there is none. the fan is working fine, when you connect it straight.
What is triggering the fan not to come on, the fuse is okay. Please help. Thanks.
