rust run under read door handles
PEDALS
Post by PEDALS »
Does anyone else have a problem with rust stains running down from under the outside rear door handles, i did a quick seach on the site but didn't find anything and i've had this issue for years!!
Vibe_dude
Post by Vibe_dude »
Not on the back handle but on the back door handles and around the back hatch inside trim..its getting bad now.....but its a 03 with 173,000 kms..so I guess its to be expected.
LOVE THAT VIBE 2003 Satilite Silver auto.......188,000kms.2006 Chevrolet Trailblazer White 4.2 Inline 6 291hp auto.........156,000kms.
moonstonemike
Post by moonstonemike »
Its most likely rust running down from the nut that holds the handle on. I had this problem too. I took the handle apart , changed out the gasket that has a nut sealed in it and voalla no more rust running down the door.
dcampman1112
Re: (moonstonemike)
Post by dcampman1112 »
does anyone have a part number for that gasket?
tribalman
Re: rust run under read door handles (PEDALS)
Post by tribalman »
Quote, originally posted by PEDALS »Does anyone else have a problem with rust stains running down from under the outside rear door handles, i did a quick seach on the site but didn't find anything and i've had this issue for years!!it is a semi-common issue. there is a bolt that rusts out, can either replace it or the gasket.
None. Vibe is gone.
silverbullet
Post by silverbullet »
Can someone put up some more info? I have the same problem and how can I fix it? Start by taking the door panel off and go from there taking apart the handle?
bogdanas
Post by bogdanas »
Hi,
I fixed mine. What I had to do it's just to replace a plastic pad under the handle. The pad has a kind of a nut in it which gets rusty. I got my new pad from Toyota dealer (Toyota Matrix) coz they had it in stock and it was cheaper than from GM (Pontiac Vibe). Pictures attached.
bogdanas
Post by bogdanas »
couple more pics
bogdanas
Post by bogdanas »
#18 is the problem
