Hi,I'm trying to hook an alarm up along with 4 actuators and two relays connected together like the ones shown on this webpage's schematic.
http://www.miata.net/garage/pwrlock.htm#Wiring RelaysI don't have any switches for my door panels yet, so everything will be manual unless i'm using the remotes, until i can buy the switches. all 4 actuators are identical, so i've run the wiring under the panels on the side but when i popped open the kick panel and removed the cover for the steering wheel and look at the wiring harnesses, I wonder what's next.I guess I'm supposed to be tapping each wire?also, aside from the wiring, the alarm brain also comes with a relay, but no instruction on where and how to use it.the manual's wiring diagrams start on page 13 if you're interested:
http://www.caralarm.com/manual...s.pdf1) it looks like i have a 3 pin connector that has +12 volts on it and the green and blue -lock and -unlock, this looks like it's what i'd be using if i had switches, but also the 9 pin connector has 2 +/- door inputs, what are these inputs for? How would i connect my locks to use only the remotes?2) the 4 pin connector next to these has a +12V connection as well. do i connect both?3) if i were to tap the wires for the already installed horn and light, would i need to put a relay between that tap? or is one already provided?4) Bonus: How do I make the front door one pulse and the rest of the doors 2 pulses? again, this manual says NOTHING about how to connect things(and i guess they'd be smart not to?)I've got a million and one more questions but i'd be greatful if you could answer these.Thanks Laser
