PCV valve and Fuel filter : where?
godar1990
Post by godar1990 »
Hi,Where is the PCV valve located on a 2003 Vibe?And how do I replace it? I purchased the part already.Also what part number is for a fuel filter and where is it located?Thanksgodar
BlueCrush
Re: PCV valve and Fuel filter : where? (godar1990)
Post by BlueCrush »
PCV Valve: VALVE COVER - Driver's side rear corner. Just take the hose off, use an open end or crescent wrench to loosen it, remove it and replace. Do it when the engine is cold so you don't burn yourself.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
godar1990
Re: PCV valve and Fuel filter : where? (BlueCrush)
Post by godar1990 »
Thanks BlueCrush
ToolGuy
Post by ToolGuy »
Quote, originally posted by godar1990 »Also what part number is for a fuel filter and where is it located?ThanksgodarThe Vibe does not have an in line replaceable fuel filter. The fuel filter is in the tank attached to the fuel pump and should never need replacement unless there is a large issue.
Siggy
Post by Siggy »
how often should it be repalced?
2003 AWD VibeVibin'
Raven
Re: (Siggy)
Post by Raven »
Never.
keithvibe
Re: (Siggy)
Post by keithvibe »
Quote, originally posted by Siggy »how often should it be repalced?when the pump fails... otherwise no user input required. LOL
Siggy
Re: (Raven)
Post by Siggy »
lol my bad i meant the PCV
2003 AWD VibeVibin'
djb383
Re: (Siggy)
Post by djb383 »
If it rattles when shaken it's probably still good but while you have it out spray brake or carb/choke cleaner in both ends to clean it out. Just checked ours (32K miles) and it was clean as a whistle. Frequent oil changes with top quality motor oil makes a big diff on how clean engine internals stay.
'05 Lava Tutone base, Pwr Grp, Moon & Tunes, 16" alloys, Auto.....Yep, it's gotta HEMI
