Hi,Where is the PCV valve located on a 2003 Vibe?And how do I replace it? I purchased the part already.Also what part number is for a fuel filter and where is it located?Thanksgodar
PCV Valve: VALVE COVER - Driver's side rear corner. Just take the hose off, use an open end or crescent wrench to loosen it, remove it and replace. Do it when the engine is cold so you don't burn yourself.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Quote, originally posted by godar1990 »Also what part number is for a fuel filter and where is it located?ThanksgodarThe Vibe does not have an in line replaceable fuel filter. The fuel filter is in the tank attached to the fuel pump and should never need replacement unless there is a large issue.
If it rattles when shaken it's probably still good but while you have it out spray brake or carb/choke cleaner in both ends to clean it out. Just checked ours (32K miles) and it was clean as a whistle. Frequent oil changes with top quality motor oil makes a big diff on how clean engine internals stay.
