Permatex Headlight Lense Restoration Kit
JohnC
Post by JohnC »
This kit works great. For $12 you can easily restore two pretty good size very yellowed plastic headlight lenses. It has 4 grit sizes of sand paper so if the lense isn't in too bad of shape you just start out with the medium grit paper then the least grit then the polishing compound and rag.I did cheat a little by using a polishing bonnet on my drill motor for the last pass.http://www.permatex.com/resource_auto_lit.htm
engineertwin2
Post by engineertwin2 »
got any photos - before/after?
JohnC
Re: (engineertwin2)
Post by JohnC »
Nope...no photos. The Permatex site has some, just follow the link and open the lense restoration pdf doc. The 97 Taurus and 04 Vibe lenses that I did looked in the same condition as the before pic., scratched and yellowed.
98ex
Post by 98ex »
This is the stuff that Toyota sells for $45
98ex
Post by 98ex »
Ok I am going to try this at home sunday based on teh video they havehttp://www.permatex.com/videos....html
Sublimewind
Re: Permatex Headlight Lense Restoration Kit (JohnC)
Post by Sublimewind »
Quote, originally posted by JohnC »This kit works great. For $12 you can easily restore two pretty good size very yellowed plastic headlight lenses. It has 4 grit sizes of sand paper so if the lense isn't in too bad of shape you just start out with the medium grit paper then the least grit then the polishing compound and rag.I did cheat a little by using a polishing bonnet on my drill motor for the last pass.http://www.permatex.com/resource_auto_lit.htmI would look toward Novus plastic polish... you could do MANY lights with even the small bottles... http://www.noscratch.com/novus/ using a mini "powerball" would save a lot of elbow grease... It's what i used to use to polish the cut edges of plexiglass for audio systems...
If only that stuff would fix the itty bitty cracks that you can see but not feel when you get where a rock smacks the light hard... I've had that happen two cars in a row now, bummer.I'm really (removed) about the appearance of my headlights, I once replaced a set on my Malibu because they were starting to yellow. That bugs the heck outta me, I can deal with the pitting to an extent but the yellow - nope. I'll have to check this stuff out if my lights get in bad shape.
Whelan
Re: Permatex Headlight Lense Restoration Kit (ColonelPanic)
Post by Whelan »
Then get some 3M LaminX to cover them, or I am pretty sure Ycart sells a headlight vinyl, just get it in clear.
2012 GLI Autobahn 6MT
