Dell Laptop Battery Recalls
slvrvibes
Post by slvrvibes »
If you have a Dell laptop purchased between April 1, 2004 and July 18, 2006, check out the link below to see if your laptop battery has been recalled for a potential risk of fire.https://www.dellbatteryprogram.com/Default.aspx
genvibe garage
ragingfish
Post by ragingfish »
only batteries are being recalled, not the computers themselves.
2009 PONTIAC G8
Atomb
Post by Atomb »
filled out the form last night and i should get my new battery in 20 business days...i always thought my laptop got pretty warm...but i think the issue is more about a 'weak spot' in the battery than just high temperature.
slvrvibes
Re: (ragingfish)
Post by slvrvibes »
Quote, originally posted by ragingfish »only batteries are being recalled, not the computers themselves.Yes that is correct I left of battery from my post.
genvibe garage
zionzr2
Post by zionzr2 »
My Wife's Dell laptop checks out fine!No new battery for her!!
Jahntassa
Re: (Atomb)
Post by Jahntassa »
Quote, originally posted by Atomb »i always thought my laptop got pretty warm...but i think the issue is more about a 'weak spot' in the battery than just high temperature.I forget why, but basically the barrier between cathode and anode corrodes or otherwise fails, letting the two short. If the short is small enough, the battery will slowly drain and just get hot, but if it happens quickly, the gasses build up and the sucker blows.
