If you have a Dell laptop purchased between April 1, 2004 and July 18, 2006, check out the link below to see if your laptop battery has been recalled for a potential risk of fire.https://www.dellbatteryprogram.com/Default.aspx
filled out the form last night and i should get my new battery in 20 business days...i always thought my laptop got pretty warm...but i think the issue is more about a 'weak spot' in the battery than just high temperature.
Quote, originally posted by ragingfish »only batteries are being recalled, not the computers themselves.Yes that is correct I left of battery from my post.
Quote, originally posted by Atomb »i always thought my laptop got pretty warm...but i think the issue is more about a 'weak spot' in the battery than just high temperature.I forget why, but basically the barrier between cathode and anode corrodes or otherwise fails, letting the two short. If the short is small enough, the battery will slowly drain and just get hot, but if it happens quickly, the gasses build up and the sucker blows.
