Quote, originally posted by BlueCrush »Welcome to GenVibe, Shane!I'm assuming your '05 is an AWD? You can tell it's an '05+ by the front fascia.If you have an '05 and its is an AWD then it would be a cable throttle.Ha, I just added the Weapon-r short ram and hitch also. I'm doing the wiring this weekend.I made my decision for the Weapon-r based on TPR Magazines Intake test & review. I have not had any CEL's either. The Weapon-r had the best gains in the low to mid rpm range which is where I spend most of my time. Here is the article:
http://www.tprmag.com/issue/1/sr-results.shtmlPost a better side shot of your vinyls when you get a chance. From what I can see it looks pretty cool! Again, welcome and enjoy your stay. Brian, what intake were you running before? I wonder if the WR is CARB exempt? I need a good CARB exempt intake for next year's smog test, and don't want to spend another $200 on Injen or K&N (Typhoon), the only two intakes I know of that are CARB exempt for the Vibe.--Back On topic--Welcome aboard, and nice vinyls
