Is there a sticky for TSBs? Technical Service Bulletins
thorntcl
Post by thorntcl »
I'm looking for the TSBs for my 2004 Vibehere is what I have found so far.http://www.alldata.com/TSB/48/044834J7. ... 6.htmlAlso found this site from the nhtsa where you can also see the list for free:http://www-odi.nhtsa.dot.gov/cars/problems/tsb/Mechanic site that provides lots of info as wellhttp://www.batauto.com/For the TSBs http://www.batauto.com/technical/tsbsta ... Volunteers perform the work so you cannot just ask for a TSB.The following article also helps understand things as well. Or if the link expires then just search the edmund site for "Technical Service Bulletin"http://www.edmunds.com/ownersh....htmlMAJOR TSBs found in the various threads:Sulphur (sulfur) smell TSB:http://forums.genvibe.com/zero...1.pdfBattery TSB:http://forums.genvibe.com/zerofile/5125/Vibe.pdfDoc. ID# 1458972 and! a TSB for the battery switch to a 560cca TSB# 03-06-03-004 New battery part # 19001602, has 560 ccacig lighter housing TSB:under TSB# 04-08-014From the battery thread:http://forums.genvibe.com/zero...ge=19Pitted rims# 1458972 is actually a PI or a preliminaryto an actual bulletin.. meaning that GM is aware of the problem and this is a fix that might work, whitch does. It's also known as PI01711Let me know if you can find more info or sites with more detail without having to pay a fee.
Cheersthor...2004 Base VibeAutomatic, black abyssTint 35 front and 20 backWish list:auto start/remote entry/lock for all doors. (no factory pwr doors or windows)
thorntcl
Re: Is there a sticky for TSBs? Technical Service Bulletins (thorntcl)
Post by thorntcl »
I've updated the info with all that I could find.
kostby
Post by kostby »
Thanks for putting it all in one place!
zionzr2
Post by zionzr2 »
what about the rotten egg or the battery TSB'swhy arnt they posted yet....EDIT: THANK YOU
thorntcl
Re: (zionzr2)
Post by thorntcl »
I've updated the first post to include the TSBs that I could find.Good luck
