I'm looking for the TSBs for my 2004 Vibehere is what I have found so far.
http://www.alldata.com/TSB/48/044834J7. ... 6.htmlAlso found this site from the nhtsa where you can also see the list for free:
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/Mechanic site that provides lots of info as wellhttp://
www.batauto.com/For the TSBs
http://www.batauto.com/technical/tsbsta ... Volunteers perform the work so you cannot just ask for a TSB.The following article also helps understand things as well. Or if the link expires then just search the edmund site for "Technical Service Bulletin"
http://www.edmunds.com/ownersh....htmlMAJOR TSBs found in the various threads:Sulphur (sulfur) smell TSB:
http://forums.genvibe.com/zero...1.pdfBattery TSB:
http://forums.genvibe.com/zerofile/5125/Vibe.pdfDoc. ID# 1458972 and! a TSB for the battery switch to a 560cca TSB# 03-06-03-004 New battery part # 19001602, has 560 ccacig lighter housing TSB:under TSB# 04-08-014From the battery thread:
http://forums.genvibe.com/zero...ge=19Pitted rims# 1458972 is actually a PI or a preliminaryto an actual bulletin.. meaning that GM is aware of the problem and this is a fix that might work, whitch does. It's also known as PI01711Let me know if you can find more info or sites with more detail without having to pay a fee.
Cheersthor...2004 Base VibeAutomatic, black abyssTint 35 front and 20 backWish list:auto start/remote entry/lock for all doors. (no factory pwr doors or windows)
