I just installed Polk EX3560 component speakers in my car tonight. I haven't had time to sort out the pictures and I'm leaving tomorrow, but I will hopefully post them Sunday. It was easy. I did however use the stock grilles (less advertising, less likely to be stolen). Crutchfield sent me a bracket that adapted between the door and speaker. The only item I bought were 2 bolts, nuts, washers for mounting my tweeters on the stock mounting bracket. You need a drill to drill out the rivets that hold the stock speakers and just some basic tools, like ratchet set and screwdrivers. The only thing I haven't completed yet is a slight modification to sail piece (where the stock tweeter is). The new tweeters have a slightly bigger frame and I need to sand down a lip a bit, but it should be cake. Also, reference this thread:
http://forums.genvibe.com/zerothread?id=1363 Also of note, I paid $150 at Crutchfield for the set. I know they don't say MOMO, but they sound great. If you spend $200 or more at Cruthfield and use my referral code you get $20 off your order and I get a $20 credit to boot. code: p7tiq-j38rv-r5w2c
