OK. So I am having quite the issue getting these BI-Xenon HID's to workThere are 3 prongs on the headlight socket for the vibe, | _ | (left, middle, right)Attached is a picture of the harness (I have removed the prongs to try switching their orientation), the white connector goes to the magnet for the position of the BI-Xenon Bulb, i.e. to turn the high beam on.Here is what I have come across so far, The only thing I think is left is to change the wiring on the harnessWith the wires at the following positions (b - black, b/r - black/red, r-red)R-BR-B = high beam on lows, light turns off when high beam selectedBR-R-B = high beam is on with high beams, no light on low beamsR-B-B/R = Low beam works, when high beam is selected magnet engages but no light on highBR-B-R = no light on low, blown fuse on highB-B/R-R = blow fuseB-R-B/R = blown fuseAnyone with BI-XENON have a similar harness? and how is it wired?Thanks
