2003 Vibe. Roof has begun to leak just above the driver side where the cloth part of the roof and the top of the windshield support meet. Any ideas where I should do?
Is it have a sunroof? If so make sure the sunroof drain hoses are not blocked or disconnected.If not check the sear on the windshield as it maybe worn and allowing water in
It does have a moonroof. I'll have to check the forum to see how to find the drains to see if they are clogged.MrsSlocum - what was wrong with yours and how did you get it fix?
Quote, originally posted by CatharineSnyder »It does have a moonroof. I'll have to check the forum to see how to find the drains to see if they are clogged.MrsSlocum - what was wrong with yours and how did you get it fix?My 07 had a leak on the drivers side, turns out the drain holes in the front (there are also rear drain holes) were plugged with tree seed pods. Pulled them out and problem solved! Easy to see, just open the roof, stick your head out and look in the front corners, you'll see two holes towards the front of the opening.Dave
