cruise lite blinks cruise will not engage again
jmsgrieves
Post by jmsgrieves »
While driving with cruise on, but not engaged, lite starts to blink, and cruise will not engage unless turned off and then back on. this started recently, any ideas?
jimincalif
Post by jimincalif »
My Lexus did this recently, after having the brake light switch replaced. Turned out the replacement brake light switch was defective. The CC has to have a circuit thru the brake light system so that it will disengage when the brakes are applied. Check to see that all of your brake lights are working, in researching this I found out that even burned out lights can confuse the CC.Both the Vibe and Lexus are Toyota, I would imagine the CC system is pretty much the same.
"We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill---------------------------------Who is John Galt?2 Vibes, 03GT & 07 base (kids drive)1993 Lexus LS4001980 Fiat Spider
joshuaeb09
Re: cruise lite blinks cruise will not engage again (jmsgrieves)
Post by joshuaeb09 »
It could also be a speed sensor thing. I know that if you have VSC it should have a speed sensors at every wheel. I know that my Cruise has the same weirdness, but that's due to the fact that I removed the governor via the unichip which basically tricks the speed senors.
2009 Silver Vibe GT AutomaticI/H/E/Unichip @ 93octaneMy Garage : http://forums.genvibe.com/zerothread?id=43521" onclick="window.open(this.href);return false; - Gone (Sold)
2005 Expedition Limited 2WD|4R75W 4SPD Auto|3.73 Gears|I/E|5Star Tuned@ 91|3" Lift/Level - Current Ride
