There seems to be this unanswered question as to what is the best high beam out there. Obviously an HID with a retrofit is probably the best option. But not all of us have the money. I'm not sure if I want to buy HIDs without a retrofit either. So what bulbs are the best?
lovemyraffe, how long have you had the phillips? how are they over the stock bulb?
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Before I did the retrofit I had the 55W HID's in there and they worked great. They didnt seem to throw too much extra light around and I was never flashed with them. There are tons of un-retrofitted HID cars around me these days....
Quote, originally posted by MotoAce51 »Before I did the retrofit I had the 55W HID's in there and they worked great. They didnt seem to throw too much extra light around and I was never flashed with them. There are tons of un-retrofitted HID cars around me these days....Just because other people do it doesn't mean it's a good idea .
Quote, originally posted by lovemyraffe »Phillips x-treme FTW! What he said. ^^^ AND the independent fog light mod. The combination of the two makes the high beams look really good. A good full pattern compared to the high beams alone.Though I am running the SilverStar Ultra's in my Mazda's high beams. For over a year now. They aren't bad, but no match for the HIDs in the low beams.
Quote, originally posted by cptnsolo77 »lovemyraffe, how long have you had the phillips? how are they over the stock bulb?I've been running the Phillips for a couple years now. They are much brighter than the stock bulb. Well worth the $ IMO.
Thanks for the update. I blew a headlight the the other day, but Walmart, Advance & Pep Boys dont carry Phillips. I just eneded up buying a standard replacemnt Silvania. They do seem brighter that the stock bulbs. Is it true that as the bulb ages it loses its brightness? That may be why my headlights seem brighter LOL.
Yea, I ordered mine off amazon and got them cheap. And yea, lights do get dimmer with age. They should start making all LED headlights... that would be sick
