RPMs
Speedqueen
RPMs
Post by Speedqueen »
Salutations,Having never had a 4cyl, manual before. I find the rpms really high compared to the other cars we've had. At 120kms (74.5mph) cruising hwy speed, the 1.8l turns about 3200 3300 rpm's. Is this what others are running? My buddy drives a Kia Spectra 2l and doesn't run nearly that high. Understand that the 4 cyl is going to run higher than the 3.8l automatic we just retired, but still surprised it runs that high in 5th gear.Is the Vibe considered a "city" car?RegardsS.
10 Vibe 1.8l, Manual, Red hot metallic (current)07 Silverado Z71 4x4 Crew cab (current)03 Monte Carlo SS 3.8l - 85 Merc Grand Marquis (cruise, tilt, bench)93 Grand AM Se 3.3l - 93 Geo Metro 1l87 GMC 1500 454 big block 85 Grand AM SE 6 cyl81 Celica GT - 76 Impala convertible hard top71 Gran Torino
ou.grizzly
Re: RPMs (Speedqueen)
Post by ou.grizzly »
Having enough RPM's to speed up is good to have, also what plays a factor is the gearing for the trans.
Speedqueen
Thank's for relocating me over to trannys Still navigating the forums.
03VibeOttawa
Post by 03VibeOttawa »
In regards to whether or not it is a "city" car - my highway mileage is only slightly better than stop-and-go city driving. Once you get above 3000RPMs, the mileage in this car isn't much better than a typical V6 doing the same.My best tanks are always when its mostly rural driving between 80 and 100km/hr.
03VibeOttawa–’03 Salsa 5spd. Fast Wheels Blade 17”s/Fuzion Zr1s (summer),Blizzak Revo1/’04 WRX rims, (winter),Tokico HP Struts,Tein S-Tech Springs,Progress RSB,K&N Typhoon SRI,SLP ram air hood,Magnaflow CB,DC header. Sold 11/9/2012 w/ 217,633kms.
Beer Belly
Post by Beer Belly »
I run around the same RPM's, just the way the car is geared i'm assuming.
KNINE
Re: (Beer Belly)
Post by KNINE »
I'm right at 3000 rpm @ 70 mph with my 5 speed. stick chick
Speedqueen
Hmmm..mine sound a bit high.I find 120kms a little slow, normal cruise speed in the Monte was 130kms on the 417 for daily commute west into Ottawa. I'd go faster but I need my licence can't afford the fine and 150 and over tends to scare other peeps on the road. I like the woosh...Wonder if I should bring it in to dealer, (understand there's a Surgenor guy here) no idiot lights on in dash lit up, maybe some uncleared codes scanner can pull up.
ou.grizzly
Re: (Speedqueen)
Quote, originally posted by Speedqueen »Hmmm..mine sound a bit high.I find 120kms a little slow, normal cruise speed in the Monte was 130kms on the 417 for daily commute west into Ottawa. I'd go faster but I need my licence can't afford the fine and 150 and over tends to scare other peeps on the road. I like the woosh...Wonder if I should bring it in to dealer, (understand there's a Surgenor guy here) no idiot lights on in dash lit up, maybe some uncleared codes scanner can pull up.Better watch those speeds near L'Orignal
Speedqueen
Re: (ou.grizzly)
Quote, originally posted by ou.grizzly »Better watch those speeds near L'OrignalAre you John Law? Luckily I don't have to go that far east. Sounds like you may have had an incident near l'Orignal.
ou.grizzly
Re: (Speedqueen)
Quote, originally posted by Speedqueen »Are you John Law? Luckily I don't have to go that far east. Sounds like you may have had an incident near l'Orignal.Initials are different, sorry.
Speedqueen
Re: (ou.grizzly)
Quote, originally posted by ou.grizzly »Initials are different, sorry. LOL Sorry I meant John Law, as in the police, the Fuzz.Cheers.
Re: (Speedqueen)
The RPM's are normal. In 5th gear I push somewhere around 3700 rpm at 140, 5000 at 185.....
Speedqueen
185. Yessssss What's rev limiter on these stock base model 1.8l. I'm still under warranty .;-)Hmmmmmm.....
Burkett1974
Post by Burkett1974 »
I have an '09 Vibe GT and at 95mph I am sitting at 3000 rpm's. At 70mph, the rpm's are around 2500 (maybe a little less). I also have the automatic with DSC, but don't think that makes much difference.
Burkett197409 Vibe GT
Re: (Speedqueen)
The speed limiter is set at 185 in both 4th and 5th gear. You can take it to about 6600 before the rev limiter kicks in (I only did that twice, by accident, and was in 2nd gear both times).There's a vid somewhere of me doing a 0-170 run... try my youtube link (in signature)Just remember... 185 = BIG ticket, charges, vehicle impoundment, ect...
joshuaeb09
Re: (star_deceiver)
Post by joshuaeb09 »
My Rev limiter kicks at 6600 as well ... I have no speedlimiter tho. Highest I've done is about 130 MPH.
2009 Silver Vibe GT AutomaticI/H/E/Unichip @ 93octaneMy Garage : http://forums.genvibe.com/zerothread?id=43521" onclick="window.open(this.href);return false; - Gone (Sold)
2005 Expedition Limited 2WD|4R75W 4SPD Auto|3.73 Gears|I/E|5Star Tuned@ 91|3" Lift/Level - Current Ride
Old Tele man
Post by Old Tele man »
...if you really want to "know" your cars' MPH versus RPM relationship, here's the equation:MPH = [ 60/(G*A)]*[ RPM/rpm ]...where:MPH = vehicle speed, miles-per-hour.RPM = engine speed, revolutions-per-minute.rpm = tire speed, revolutions-per-mile.60 = conversion constant, minutes-per-hour.G = transmission gear ratio, ie: 1.00:1, 0.745:1, etc.A = axle gear ratio, ie: 3.55:1, etc....get tire rpm from your local tire shop or website. Actual number depends upon tire and wheel diameter, but typically a number between 900 and 800, roughly.
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
