Wow guys, this stuff works like a charm! I saw a member on another forum that i'm currently in and thought id give it a shot. Came out great! So far, I've painted the "Vibe" on each side black and came out awesome! Steps for doing this is easy! All you gotta do is cover the area you paints, you dont have to be perfect. (Leave alittle space to peel the paint!)Next you just spray the plastidip to the area you wanted, do 3 coats! one light one, and two heavy ones.After the three coats, Grab a toothpick and go around the tape to spread it apart.Once you've done that, Basically remove the tape or whatever you used.After you've done that, Let it dry for 30mins to and hour. Once dried, Grab one corner and begin to peel away.Make sure you got all the paint off, and to get into the tight areas with a toothpick. Step back, and enjoy a cheap/Temporary mod!
Well i've researched around and they say it'll hold up pretty well. But i'll definitely keep you guys updated. This stuff is durable too! Im testing the paint on rims right now. Soo far, they look nice!
Wow that's crazy. Did you do any surface prep prior? I might try this, I was planning to pull off my emblems to paitn black. I need a durable paint for my winter rims too
Quote, originally posted by MotoAce51 »Did the wheel hold up or chip off?+ 2 I gotta know! If nobody can say, I guess I'm doing it as soon as I can get my hands on a few cans. I will let you know if you haven't found ou yourself. There are some videos on YouTube that make it sound like a good deal if done properly.
Sorry guys, didn't see you guys were posting here. But the rims held up pretty well. But about a week ago, i was washing the truck, and the paint started to peel off, But was no biggy anyways, im gonna actually paint the rims soon. But the paint held up pretty good. No chips, nada. id say, about 5 months with the paint still on the rims, till last week, id say its some wicked sh*t. wish it was permanent thou. lol. but the paint on the emblems is still holding up strong!
Thanks for the update! I've got the local Ace ordering me three more cans, will probably do this this week actually, then touch up or get steelies for winter.How many cans did it take?
i used 4 cans for the rims, But i've noticed a better result when the rims were somewhat warm, if the rims are cold, paint will bubble where you dont want it too, If its warm, itll dry once its on in 5mins. Do light coats thou, after you have about 3 coats, do one last heavy coat to get any spots missed.
He's absolutely right about the last heavy coat. Do it as heavy as you can without it running.Before it dries it will have a weird texture, but once it dries up it takes on the texture of whatever you sprayed it on.It's pretty neat
Thanks for that tidbit about the texture, I might have freaked out! I am used to spraying clearcoat which you do not want ANY texture on or you goofed up.
