Where did I see this?
zubenal
Post by zubenal »
I saw in this forum a discussion on a plug that I think is in the block that is removed to allow more sludgy oil to drain. Doing this, I read, improves the performance.I cant find that thread. There was even a diagram to show where the plug is.Can someone point me to this?Thanks
04chargedvibe
Re: Where did I see this? (zubenal)
Post by 04chargedvibe »
If i remember correctly i believe its this onehttp://forums.genvibe.com/zerothread?id=42494
zubenal
Re: Where did I see this? (04chargedvibe)
Post by zubenal »
YESSSSS.Thanks.I have to print out the diagram to show it to my mechanic.
DoubleBaril
Post by DoubleBaril »
im guessing this has to be done at the time of an oil change?
2003 Vibe AWD
millster
Re: (DoubleBaril)
Post by millster »
Quote, originally posted by DoubleBaril »im guessing this has to be done at the time of an oil change? Not necessarily. Oil is only flowing through this while the pump is running. I'd question whether, for the normal owner, any "performance increase" would be noticed by cleaning the valve and filter. If you've been lax on maintenance, possibly. Mostly, this valve becomes suspect in cases of the engine "falling on its face" in the RPM ranges where the valve timing is varied (the first of which is right around 3,000 IIRC).
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
NascarXprt
Re: (millster)
Post by NascarXprt »
if i am having bad mpg (around 25-27) would this improve my MPG if i were to clean and replace it? BTW i have 110,000 miles on the car.
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
