Hey Guys,So I recently bought a 6000K hi/Lo HID kit. When I was installing I noticed that it the low beams would not come on. In fact, none of the bulbs came on. But when I flashed my Hi beams, they would light up. Any suggestions on solving this problem?Thanks
First did you disable your drl?my guess is the wire harness plug prongs are in the wrong location. You will need to remove the prongs from the harness and relocate them to the correct location.What I am saying is it sounds like the ground and low beam prongs need to be swaped
Hey,Thanks! I was guessing that I needed to re-wire the prongs. I tried the lights on a 96 civic and it worked fine! I'll do that asap! The Kit is called "HID Xenon Power Light Conversion Kit" I got it from Pacific Mall for $80. I don't think it's a specific brand. Its a 6000K H4 Hi/Lo kit! Pretty straight forward for the most partThanks
