I once bought an extra FOB for my 2003 on eBay.Seems to me it was about $20 including shipping.If I could find it I'd offer it for sale.
Quote, originally posted by kartrac3r »are they easy to program?From the Service Manual:Rewrite Mode (deletes old codes and adds new code)1. Setup:- ignition is off and key out- all doors closed except driver door- driver door unlocked2. insert and remove ignition key twice within 5 seconds3. close and open driver door twice in 40 seconds4. insert and remove ignition key once5. close and open driver door twice in 40 seconds6. insert ignition key7. close driver door8. turn ignition from LOCK to ON (not START) and back to LOCK 2 times9. remove ignition key10. system should LOCK and UNLOCK doors (once or twice) to confirm rewrite mode11. within 40 seconds simultaneously press the LOCK and UNLOCK buttons of the fob for 1 to 1.5 seconds. Then within 1 second press either the LOCK or UNLOCK button on the fob12. doors will LOCK and UNLOCK once if code is accepeted. If the they LOCK and UNLOCK twice, the code was not accepted and you need to repeat steps 11 and 12.13. to add another transmitter code (up to 4 codes total) repeat steps 11 thru 13.
2011 Rav4 Sport
From the Service Manual:Rewrite Mode (deletes old codes and adds new code)1. Setup:- ignition is off and key out- all doors closed except driver door- driver door unlocked2. insert and remove ignition key twice within 5 seconds3. close and open driver door twice in 40 seconds4. insert and remove ignition key once5. close and open driver door twice in 40 seconds6. insert ignition key7. close driver door8. turn ignition from LOCK to ON (not START) and back to LOCK 2 times9. remove ignition key10. system should LOCK and UNLOCK doors (once or twice) to confirm rewrite mode11. within 40 seconds simultaneously press the LOCK and UNLOCK buttons of the fob for 1 to 1.5 seconds. Then within 1 second press either the LOCK or UNLOCK button on the fob12. doors will LOCK and UNLOCK once if code is accepeted. If the they LOCK and UNLOCK twice, the code was not accepted and you need to repeat steps 11 and 12.13. to add another transmitter code (up to 4 codes total) repeat steps 11 thru 13.sounds like a more complicated version of the chinese fire drill
Quote, originally posted by kartrac3r »sounds like a more complicated version of the chinese fire drillYou feel like a complete idiot while sitting in your driveway with your neighbors watching you do this, but it does work.
You forgot the "put your left foot in, pull your left foot out . . . "
