key blanks
kartrac3r
key blanks
Post by kartrac3r »
where is the most reputable to get a key blank and keyfob without paying out the nose?
05 Vibe
06 HHR LT2
86 Grand Prix 2+2 Aerocoupe
jake75
Re: key blanks (kartrac3r)
Post by jake75 »
I once bought an extra FOB for my 2003 on eBay.Seems to me it was about $20 including shipping.If I could find it I'd offer it for sale.
ou.grizzly
Post by ou.grizzly »
Do you need a key fob for a 2003-2008 Vibe or a 2009+ Vibe?
lovemyraffe
Re: key blanks (ou.grizzly)
Post by lovemyraffe »
I have an extra key fob I'd be willing to part with.
kartrac3r
Post by kartrac3r »
its for an 03-08. Another question, are they easy to program?
05 Vibe
06 HHR LT2
SlammedNiss
Re: (kartrac3r)
Post by SlammedNiss »
Quote, originally posted by kartrac3r »are they easy to program?From the Service Manual:Rewrite Mode (deletes old codes and adds new code)1. Setup:- ignition is off and key out- all doors closed except driver door- driver door unlocked2. insert and remove ignition key twice within 5 seconds3. close and open driver door twice in 40 seconds4. insert and remove ignition key once5. close and open driver door twice in 40 seconds6. insert ignition key7. close driver door8. turn ignition from LOCK to ON (not START) and back to LOCK 2 times9. remove ignition key10. system should LOCK and UNLOCK doors (once or twice) to confirm rewrite mode11. within 40 seconds simultaneously press the LOCK and UNLOCK buttons of the fob for 1 to 1.5 seconds. Then within 1 second press either the LOCK or UNLOCK button on the fob12. doors will LOCK and UNLOCK once if code is accepeted. If the they LOCK and UNLOCK twice, the code was not accepted and you need to repeat steps 11 and 12.13. to add another transmitter code (up to 4 codes total) repeat steps 11 thru 13.
2011 Rav4 Sport
ou.grizzly
Re: key blanks (A Psycho Martyr)
Quote, originally posted by A Psycho Martyr »Ummmm.... key FOB?
kartrac3r
Re: (SlammedNiss)
Post by kartrac3r »
From the Service Manual:Rewrite Mode (deletes old codes and adds new code)1. Setup:- ignition is off and key out- all doors closed except driver door- driver door unlocked2. insert and remove ignition key twice within 5 seconds3. close and open driver door twice in 40 seconds4. insert and remove ignition key once5. close and open driver door twice in 40 seconds6. insert ignition key7. close driver door8. turn ignition from LOCK to ON (not START) and back to LOCK 2 times9. remove ignition key10. system should LOCK and UNLOCK doors (once or twice) to confirm rewrite mode11. within 40 seconds simultaneously press the LOCK and UNLOCK buttons of the fob for 1 to 1.5 seconds. Then within 1 second press either the LOCK or UNLOCK button on the fob12. doors will LOCK and UNLOCK once if code is accepeted. If the they LOCK and UNLOCK twice, the code was not accepted and you need to repeat steps 11 and 12.13. to add another transmitter code (up to 4 codes total) repeat steps 11 thru 13.sounds like a more complicated version of the chinese fire drill
05 Vibe
06 HHR LT2
lovemyraffe
Re: (kartrac3r)
Quote, originally posted by kartrac3r »sounds like a more complicated version of the chinese fire drillYou feel like a complete idiot while sitting in your driveway with your neighbors watching you do this, but it does work.
jake75
Re: (lovemyraffe)
Post by jake75 »
You forgot the "put your left foot in, pull your left foot out . . . "
