rear wiper
kartrac3r
rear wiper
Post by kartrac3r »
excuse my ignorance. but I just bought my vibe a couple of days ago. and it needs new blades all around. I got the fronts replaced, but how does the rear one come off? Do I just need to just remove the rubber portion itself? or can I take it off like the fronts?
05 Vibe
06 HHR LT2
86 Grand Prix 2+2 Aerocoupe
Wolfman213
Post by Wolfman213 »
You can just replace the rubber. Best bet it to buy a replacement blade twice the length so you can cut it in half to have two uses out of one blade. Make sure you keep the metal supports in case the new one doesn't come with any. Otherwise, I think it's around $15 for the whole rear piece, plastic included.
cptnsolo77
Post by cptnsolo77 »
When I replaced my front blades, I cut the rubber on the old blade & used it for the rear wiper. Save $$$
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
kartrac3r
Re: (cptnsolo77)
Post by kartrac3r »
thanks for the advice guys!
05 Vibe
06 HHR LT2
09vGT
Post by 09vGT »
Does yalls rear wiper seem to wear out WAY before the fronts.. because it seems to be the case for me..
areles
Re: rear wiper (kartrac3r)
Post by areles »
This may not be cheap, but Trico now makes Exact Fit replacement blades for our Vibes. At substantial savings over my dealer's cost for the factory blade. 2009-10 Blade, driver side (Exact Fit) = 26-12009-10 Blade, passenger side (Exact Fit) = 17-12009-10 Blade, rear (Exact Fit) = 11-A
cptnsolo77
Re: (09vGT)
I dont use my rear wiper that often. In the morning to wipe off the dew & also in HEAVY rain during rainy season.
