Stall and loss of power
Gil
Post by Gil »
Hi,Today I pulled out of the drive way and my 06 Vibe with 64,000 kilometers stalled. It took several tries to get it started and when it did there was almost no power. Pedal to the floor and it barely revved at all. If I took it out of Park or Neutral it would sputter. The Check Engine Light also came on.So I let it sit for a few minutes then it started right up, full power and but the engine light was still on. I drove it for about 20km, and when turned off the engine and restarted, it was fine and no Check Engine. What could be going on here?? Is this the dreaded PCM problem I have been reading about on here?Thanks,
keithvibe
Re: Stall and loss of power (Gil)
Post by keithvibe »
any mods done/ cai ect?could be a vacuum leak, have you had any recent engine work done?
Gil
Post by Gil »
No, on both of those.
lovemyraffe
Re: (Gil)
Post by lovemyraffe »
Can you give a few more details? Is the engine acting funny, can you get the motor to redline while in gear? If you can get a CEL back, get the code. That will help diagnose it.
DiveNut
Post by DiveNut »
Initially it looked like you may have been in "limp mode" and perhaps a bad MAF sensor. But the fact that it runs OK now eliminates that. Perhaps an ECU type thing? It will be pretty easy to diagnose the problem if you can provide teh CEL code.
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
keithvibe
Post by keithvibe »
first I would reset the ecu. disconnect your battery for a few mins. Reconnect it and let us know if it's still happening. It takes the ecu a few start stop cycles to relearn.
Almost sounds like you had a little water in the gas tank. Sucked it up, sputtered, ran it through and now it's fine.
Gil
Post by Gil »
Happened again today, but this time it wouldn't even start until 3 or 4 tries. Same as before, once started wouldn't rev past 1500. when it was running, the rpms would fluctuate up and down sporadically, but turning on the AC and fans would cause the rpms to drop and almost stall again. Turned it off for a while and then it started up fine and ran ok, but the engine light stayed on this time. So hopefully this will remain so they can get a code.Up until this happened the car worked fine except for occasional rpm and gear change when coasting on hill, but from I what read, this seems normal. Although, there was occasional very slight hesitation when hitting the gas after a stop light/sign.
Gil
Post by Gil »
The above happened for a second time today, so I decided the disconnect the battery to see if that would reset anything... Well, after reconnecting the battery if struggled to start once, stalled and now won't start at all. Looks like I'm going to have to get the F-ing thing towed to the dealership now.Also, when I reconnected the battery the park lights seemed to flash a couple times, not sure if this is normal?
keithvibe
Re: (Gil)
Post by keithvibe »
Quote, originally posted by Gil »The above happened for a second time today, so I decided the disconnect the battery to see if that would reset anything... Well, after reconnecting the battery if struggled to start once, stalled and now won't start at all. Looks like I'm going to have to get the F-ing thing towed to the dealership now.Also, when I reconnected the battery the park lights seemed to flash a couple times, not sure if this is normal?Have you had the battery, alternator, and starter checked?I know I didn't mention how to disconnect the battery, but disconnecting the negative cable first then postive second is the correct way to do it.The parking lights shouldn't flash, unless you have a car alarm.
Gil
Post by Gil »
Re: battery, alternator, and starter - haven't had them checked but the car is at the dealership now, so will see what they find.
Gil
Post by Gil »
It was the PCM. Repaired under warranty!
Wolfman213
Post by Wolfman213 »
Glad you got it taken care of, esp under warranty!
lovemyraffe
Re: (Wolfman213)
That makes sense. If the PCM is bad, it doesn't always throw a code. Glad you got it taken care of.
Re: (Gil)
Nice that it was fixed for free!!!!
