Radio Pops
Kelpie
Radio Pops
Post by Kelpie »
I just put in a Panasonic head unit on an '03 Vibe with Moons and Tunes. It pops real loud when I turn on the unit, when I turn off the unit, when I change components from radio to cd and then to XM, when I change radio and XM stations, and when I forward through a CD.I wired up a metra harness to the pre amp outputs to avoid the problems that I read here with the amp. I thought if rewiring it with the Scosch thing that allows one to modify the gain on the regular output, but I don't know that it would solve the popping noises.Anyone have any suggestions?
audiovibe
Post by audiovibe »
Are you running the factory amp still?
keithvibe
Re: Radio Pops (Kelpie)
Post by keithvibe »
I have first hand experience with this.I'm running an aftermarket HU, I wired in the scosche and adjusted the gains of the speaker levels. I had no popping issues. Then the scosche took a dump and i removed it and wired the HU direct to the factory amp with the speaker wires, I now have the popping noise you are having. I am going to wire in a new scosche today to stop the popping again.So yes if your running the factory amp yes you will need the scosche to get rid of the popping.
Re: Radio Pops (keithvibe)
That should help immensely. It will eliminate the popping and I'm sure you're hearing excessive white noise as well.Another option is to just bypass the thing. I think I heard they now have some new fangled harnesses that do the job for that. That would have been nice to have years ago.
Image Image
Kelpie
Re: Radio Pops (ColonelPanic)
Post by Kelpie »
Yeah, I am using the factory amp.I'll go ahead and get the scoche thing. I had it wired through the usual wire harness earlier and had the hiss. but no popping. Should I wire the scoche from the usual harness and not the pre amp outputs?
keithvibe
Post by keithvibe »
wire it inline between the radio and the plugs that plug in to the factory plugs using the speaker wire inputs
Kelpie
Post by Kelpie »
Well, I got the Scosche thing and everything works great.Thanks for the input and advice.
