Oil Question
RedRocket
Oil Question
Post by RedRocket »
We got our first Pontiac Vibe last month,a 2004 model with the 1.8L engine that holds 3.9qts of oil..Love the little car so far..Gets awesome gas mileage..Question is, will putting 4qts in it hurt it? Because I went over while changing it and put 4qts in it.I was trying to watch it,but it went over just a tad..And another question, is the 5w-30 really the best for it? Or would 10w-30 be better? I've always used 10w-30 in all my other vehicles,but wonder if it might be hard on the engine and the oil pump with the engine being so small and the 30 wieght oil being thicker..
2004 base Vibe- Automatic
djkeev
Re: Oil Question (RedRocket)
Post by djkeev »
I wouldn't sweat the tiny little bit of extra, no biggie.The weight, use what they recommend on the oil cap, 5w20. The engines are built to a very close tolerance and the thinner oil presents less friction which in turn presents better mpg's.Dave
(o ! /o) (o)=I=(o)
RedRocket
Post by RedRocket »
I just ran back out and check the oil cap,it says 5w-30
ou.grizzly
Re: Oil Question (djkeev)
Post by ou.grizzly »
Quote, originally posted by djkeev »I wouldn't sweat the tiny little bit of extra, no biggie.The weight, use what they recommend on the oil cap, 5w20. The engines are built to a very close tolerance and the thinner oil presents less friction which in turn presents better mpg's.Dave5w20 for the 09/10 Vibes with the 1.8L Engine and 0w20 for better mileage is recommended. 5w30 for the 03-08 Vibe with 1.8L Engine is recommended.
djkeev
Re: Oil Question (ou.grizzly)
Post by djkeev »
Quote, originally posted by ou.grizzly »5w20 for the 09/10 Vibes with the 1.8L Engine and 0w20 for better mileage is recommended. 5w30 for the 03-08 Vibe with 1.8L Engine is recommended. Yep, what he said ^^^^^ I actually meant 30 but brain didn't communicate effectively with fingers! Also when working on memory (which is fading) the multiple vehicles I service get muddled together!! Getting old sucks!
(o ! /o) (o)=I=(o)
