new member with tire question
coolchange70
Post by coolchange70 »
will 225/55/16 on stock alloy wheels fit without clearance problems07 vibe
06pvibe
Re: new member with tire question (coolchange70)
Post by 06pvibe »
'Don't know about clearance, but they are too big for the 6.5" OE wheels. And there will be other problems too.1) Will bulge on the OE wheels. Bad for ride and handling.2) Added unsprung weight. Bad for power, handling and fuel mileage.3) Added mileage on the ODO. Bad for resale value, fuel mileage calculation.Stick with something that will fit properly (circumference especially) and you'll be much happier in the long run. Up-size to a plus 1 size if you must, but be conservative (17" or 18") or you'll likely do more harm than good. Your ride will be unsafe, and a handful in day-to-day traffic.
lovemyraffe
Post by lovemyraffe »
225 seems really wide. I agree with 06pvibe, stick with something that will fit the wheel properly. I had 205/60/16 on my car for a while and many other members have done the same.
jkm311
Re: new member with tire question (lovemyraffe)
Post by jkm311 »
I'm also putting the 205/60/16s on my alloys in the spring. I wanted just a bit more cushion than 205/55/16s. Michigan roads in spring.
Steelies to the rescue.
coolchange70
thanks for the info. just wanted a little wider maybe little taller. 215/55/16 might be better I think I saw someone say they used that size.
Sublimewind
Post by Sublimewind »
The width difference between a 205 and a 225 is 2cm, not a HUGE difference.. not one that I'd be overly concerned about on a passenger car... If it where my show/race car, I'd be much more concerned... The height difference is nominal as well, as long as you know it will change the speedo slightly...
HighMileVibe
Post by HighMileVibe »
You have it backwards PVibe - the taller tire will result in FEWER miles for a given speed. It may actually result in a MORE ACCURATE speedometer because the factory calibration seems to be about 4% too high. The 225/55 is about 3.5% taller so your speedo should be about dead on.As for fit, there seems to be plenty of wheel well room on the Vibe so I would not expect any issues. They will appear to bulge off the rims just slightly but I doubt anyone but a very experienced driver would ever notice any driving difference.
2006 Platinum base, Auto, 145k miles+, now a 2004 Matrix 190k+ mods: Leather wheel, Homelink dimming mirror, ribbed cargo mat, blackberry mount, Jensen VM8023HD HU, mudflaps, bumper guard, double armrest Other cars: 97 Accord Coupe, 2000 GMC Savana conversion, 97 Miata M-edition. http://forums.genvibe.com/zerothread?id=37345 http://www.gotlife.org
~MRVIBE2006~
Re: (HighMileVibe)
Post by ~MRVIBE2006~ »
Ive had 225/50/16 on the stock alloys with no problem plus that size is almost an exact replacement for the 205/55/16 tires. I have 215/55 on my stock alloys for winter (Dunlop winter sport M3) and have had no problems. Like they said, I wouldn't go much above a 17" with a 235 /45 tire. much bigger and lower profile and you'll run the risk of wheel damage and rougher ride. Good luck!
2006 ABYSS VIBE: 20% TINT ALL AROUND FRONT & REAR SPLASH GUARDS MAGNAFLOW CAT-BACK EXHAUST GOODYEAR EAGLE GT (235/45/17) WITH TC WHEELS (SUMMER) DUNLOP WINTER SPORT M3 (215/55/16) ON STOCK ALLOYS (WINTER) AUTO VENTSHADE WINDOW VENTS PLUS SUNROOF VENT K/N AIR FILTER,OTHER DRESS-UP GOODIES...
Dino
Post by Dino »
I don't know about the clearance, but I would be concerned about hydroplaning. My car was terrible on wet roads using the factory 205/55R16 tires that came on it. I normally drive by myself, so the car is light. Keeping it on wet roads in Louisiana was a challenge, and heaven forbid you try to use the cruise control. I went to a tire with high ratings for handling wet roads and it improved a lot. Wider tires will make driving on wet roads worse. Just my 2 cents worth.
