09 2.4 Gas mileage.
The latest news on what's happening with the Pontiac Vibe & Toyota Matrix.
bigdaddyjosh
09 2.4 Gas mileage.
Post by bigdaddyjosh »
What are people getting? I bought my car used with 30k miles. I just ran my first tank through and currently have 1/16th tank left in it. According to mileage gage ive only drove 212 miles. When I filled I put in just over 13 gallons. This is all city driving, with few stops.
Pioneer AVH-P8400BH HU Polk Audio DB-6501 Components Pioneer GM-6400F Amplifier K&N drop-in filter Fiberglass Sub box w/10" Cerwin Vega
ponta2147
Re: 09 2.4 Gas mileage. (bigdaddyjosh)
Post by ponta2147 »
My car is too new to really know what MPGs (just over 2,000 miles) but my '09 2.4L has been getting between 23-25 mpg so far... this is about 1/3 highway and 2/3 city, keeping in mind I have a bit of a lead foot so it hasn't been the most efficient driving (going really fast, lots of starts and stops, etc).
bigdaddyjosh
Re: 09 2.4 Gas mileage. (ponta2147)
I should note that i did use the sport shift an awful lot this tankful.
Entelodont
Post by Entelodont »
The last tank full yielded 24.1 MPG, 50/50 city / hwy on 100% gas, no ethanol. It's an automatic.
PlatinumVibe08
Re: 09 2.4 Gas mileage. (Entelodont)
Post by PlatinumVibe08 »
Quote, originally posted by bigdaddyjosh »What are people getting? I bought my car used with 30k miles. I just ran my first tank through and currently have 1/16th tank left in it. According to mileage gage ive only drove 212 miles. When I filled I put in just over 13 gallons. This is all city driving, with few stops. I should note that i did use the sport shift an awful lot this tankful. Yikes, 16 MPG sounds pretty scary, sport shift or not. In any event, this topic has been discussed quite a bit previously on genvibe. Here are links to at least two threads on the subject.Fuel mileage question for 2.4L owners.2.4L Gas Mileage?Quote, originally posted by Entelodont »The last tank full yielded 24.1 MPG, 50/50 city / hwy on 100% gas, no ethanol. It's an automatic. Where are you getting 100% gasoline with no alcohol? I've heard that Casey's General Store sells 100% gas as the 87 octane, but I don't know for sure.
2006 Lexus SC430 White Gold Crystal
2010 Lexus RX350 Matador Red Mica
2013 Lexus CT200h Starfire Pearl
gimmegimme
Post by gimmegimme »
My '09 GT auto averages about 20 mpg, doing mostly city driving.
Tonebalone
Post by Tonebalone »
When I first bought my '09 2.4, I was getting about 22, mostly city driving. After 3 months, I was getting 27. 100% gas, no ethanol.You can expect a decrease in fuel economy in the winter. I think it's due to a different cold weather gasoline blend, and the density of cold air.
Entelodont
Re: (gimmegimme)
Casey's General Store is the place; in Iowa the specific grades must be marked accordingly. I talked to the tanker driver unloading there to confirm that 87 octane is 100% gas. Sam's Club up here has a couple of 100% gas pumps as well. I'm not sure if that is the case in Illinois.
bigdaddyjosh
Re: (Entelodont)
Ok I did alot of highway miles yesterday and I got around 27.5 mpg. This was all without using manual mode. I can be happy with that.
jd521
Post by jd521 »
On both of our 2.4 L Vibe Gt's . We measured 29 and 29.3 mpg respectively just last weekend. That was on a 406 mile one-way trip. I felt like that was pretty good. I was surprised it was that even. The jet black Vibe was the better and has only 5,000 miles on it whereas, my red one has over 29,000 miles. Very pleased !
Entelodont
Re: (jd521)
My Vibe attained 32.2 MPG with 650 Lbs. of payload on a road trip to see the NFL Aint's VS the Lambs on a November road trip . At 65 MPH and passing , when necessary.
PlatinumVibe08
Re: (Entelodont)
Quote, originally posted by Entelodont »Casey's General Store is the place; in Iowa the specific grades must be marked accordingly. I talked to the tanker driver unloading there to confirm that 87 octane is 100% gas. Sam's Club up here has a couple of 100% gas pumps as well. I'm not sure if that is the case in Illinois.Thanks Entelodont! Now I'm going to need to do some mpg comparisons to see if I can justify spending 15 cents extra per gallon at Casey's General Store vs. Kroger.
I've had 12 fill-ups since May 2009 when I purchased my 2009 Vibe GT. The best tank yielded me 31.1mpg and the worst 25.1. Also the best distance was 342 miles and took 11.9 gallons to top it off. Average of my 3645 miles so far, using 132.1 gallons = 27.6 mpg. Very pleased with those results! The "manual 5-speed" transmission makes a noticeable difference in the better numbers over an automatic. I just wish the fuel tank were bigger (15-16 gal instead of 13) so we could all drive a bit further between fill ups!
Forgot to mention that all those numbers reflect an honest 1/3 highway & 2/3 city driving with short stops in general. If stuck at RR crossings or major traffic jams.. I shut the Vibe down! I generally drive conservatively!
ou.grizzly
Post by ou.grizzly »
I have been averaging about 22 mpg with my 09 AWD. Can go about 230 miles per tank. I will be going in for my 1st oil change tomorrow.
Mattsky
Post by Mattsky »
I got 32 mpg on a trip that was all highway driving. It was a 90 degree day and I had the AC cranking. I kept the car between 55 and 60 mph. The return trip I averaged about 65mph and the mileage went down to 29mpg. All city driving I get 19 mpg
Airmack
Post by Airmack »
is this sport shift only on GT's?I have a 09 AWD & I get like 21mpg
gimmegimme
Re: (Airmack)
Quote, originally posted by Airmack »is this sport shift only on GT's?The sport shift is on the 5-speed autos (available on 2.4L FWD models).
bigdaddyjosh
Re: (ou.grizzly)
Ive filled up 5 or so times since the time of my initial post and can honestly say fuel consumption hasn't gotten any better. 99% of my driving consists of all city driving and 50 percent of that keeps me under 25mph. I work on a military base so... on avarage I get 210 miles between fillups, pretty gnarly compared to my last car that got 230 miles on a 9 gallon tank.
Tonebalone
Re: (bigdaddyjosh)
Like I said before, I've been getting 27 mpg with my base 2.4 with the 5-speed auto. To the OP: if you put just over 13 gals in, that fuel dealer might be cheating a bit, or you like living close to the edge. I thought the tank only held 13.2 gals.
vibolista
Re: (bigdaddyjosh)
Post by vibolista »
Drive as smoothly as you can, anticipate stops to let off the gas sooner when nearing stop signs, traffic lights. Check your tire pressure. 40 psi fronts and 38 rears if you can stand the firmer ride. Always accelerate gently. You'll save lots of gas and money!!
enfield577
Re: (vibolista)
Post by enfield577 »
'09 GT 2.4L auto ... 30-32mpg pure highway, about 27 driving backroads to-from work daily.
skidoo.1
Post by skidoo.1 »
I'm from Ontario, my VIBE 2009 5 speed is supposed to get 39 mpg. 7.2 km / 100 k... not happening! lucky to get 31 mpg and the fuel light comes on at 500 km. My COBALT got 650 km per tank on a bad day! I travel all hwy. Don't boast good mileage and then don't deliver or I would have picked a different vehicle. Love the space and the handling but not the mpg!!!
PlatinumVibe08
Re: (skidoo.1)
Quote, originally posted by skidoo.1 »I'm from Ontario, my VIBE 2009 5 speed is supposed to get 39 mpg. 7.2 km / 100 k... not happening! lucky to get 31 mpg and the fuel light comes on at 500 km. My COBALT got 650 km per tank on a bad day! I travel all hwy. Don't boast good mileage and then don't deliver or I would have picked a different vehicle. Love the space and the handling but not the mpg!!!You didn't specify which engine you have, but neither was rated at 39 mpg, at least here in the good 'ole USA. The 1.8L 5-speed was rated at 26 city/32 hwy and the 2.4L 5-speed was rated at 21 city/28 hwy. Sounds like your Vibe is right on target.
Re: (PlatinumVibe08)
In Canada we use Litres per 100km and Imperial MPG. Makes a big diffrence when you have 4.55L per Gallon (Imp.) vs. 3.78....And based on the numbers he gave, he has the 2.4... and probably drives the 400 series of highways at 130km/h like everyone else. Keep it at or below 100km/h and you'll see that 7.2L/100km.(Note to self: For better mileage, drive like Granny)
Re: (star_deceiver)
I got 33.9 mpg on my '09 2.4L (K&N Typhoon intake) on my trip from Sandwich, Illinois to the Wisconsin Dells this past weekend. I drove 65-70 mph depending on traffic (speed limit was 65). 20 miles or less of the trip was slow driving (25-30 mph) around the Dells, the rest was all highway. I made it there and back (approximately 180 miles one way) on one tank with at least 2.5 gallons to spare (the low fuel light came on 4 miles from the gas station).I am very pleased with the Vibe's performance on this road trip. I average 27-29 mpg with 50% city/50% highway so this 10% city/90% highway was a 3-5 mile gain. Not bad at all in my opinion .
ponta2147
Post by ponta2147 »
Getting my tires filled back up after a winter of evil potholes made a huge difference in mpg... I'm back up to 29/30mpgs with half city half highway. That's *just* where I want it, and maybe a new intake will improve that by 1 or 2....... (since I'm certainly not going to try to drive more conservatively, lol)
sbzero
Re: (Mattsky)
Post by sbzero »
I was getting the same until I replaced my rear differential fluid and transfer case fluid with Mobil 1 75w90, now I get 27 mpg usually.
