Every 1.8 I have seen comes with 16" wheels. Did Pontiac offer 17" or 18" as an option on with 1.8???
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Ahhhh I see. Just entertaining thoughts of my next car. The 09 Vibe is definitely an option, but not the 2.4. Looks like the gas mileage isnt so great. If Im going to take a dip in MPG it will be on a larger car. Thx.
You don't want the 18's. I have a GT and it came with the 18's. Now I need new tires, and can't find a set for under 800 bucks. So unless you can afford the outrageous prices for the performance tires then I wouldn't get them.
You're looking in the wrong places.Tirerack has the OEM tire for $112 each and an $80 rebate on top of that when you buy 4. Shipping is around $50.http://www.tirerack.com/tires/...dex=0
Quote, originally posted by BahamaTodd »You're looking in the wrong places.Tirerack has the OEM tire for $112 each and an $80 rebate on top of that when you buy 4. Shipping is around $50.http://www.tirerack.com/tires/...dex=0+1And if you want the 17's, Tire Rack has the OEM Goodyear for $85 each with a $40 rebate when you buy 4.
Quote, originally posted by midnightthunder89 »My dealer would not install anything bigger than the 16 in wheels on the 1.8...Probably because as far as the factory Vibe wheels are concerned, the 17s and 18s won't fit because they have a different bolt pattern from your 1.8L.
