Quote, originally posted by keithvibe »are you running a cai?I had 3 P0171 codes last summer with my CAI, none since I plugged back the stock air box 3 months ago for winter.I reset the code with my SCII and kept going.If it happens too often, check for leaks around the silicone links or at the filter.You could also reset the whole thing by unplugging the battery for half an hour or so and start the engine on idle for 15 minutes so the computer adapts itself. Exept some rough idling where the computer adapts and drive slowly until everything is back to normal.Quote, originally posted by
http://www.aa1car.com/library/ford_lean_codes.htm »WHAT A LEAN CODE MEANSA lean fuel condition may exist if the engine is sucking in too much air and/or the fuel system is not delivering enough fuel. If bad enough, a lean fuel condition may cause lean misfire, a rough idle, hesitation or stumble when accelerating, and/or poor engine performance.So basically the CAI is doing it's job  it's just the engine not expecting so much breathable air.
