Rough ride
bigdaddyjosh
Rough ride
Post by bigdaddyjosh »
I have a bone stock 09Vibe 2.4. Why is the ride so rough. I feel every bump and divit in the road. Also there is a noticable clunk coming from the liftgate area when going over some bumps.
Pioneer AVH-P8400BH HU Polk Audio DB-6501 Components Pioneer GM-6400F Amplifier K&N drop-in filter Fiberglass Sub box w/10" Cerwin Vega
JetBlack09VibeGT
Re: Rough ride (bigdaddyjosh)
Post by JetBlack09VibeGT »
You might want to check to see if the spare tire and or jack is tightened down. Vibe suspension is inherently stiff, so keep in mind, if you're going to move to a larger diameter wheel, the ride will become more harsh.
The rough ride is normal.That clunk is caused by the tailpipe hitting the rear bumper. Here's where it normally sits.It can move up pretty easily with a big enough bump...
B14CK_H4WK
Post by B14CK_H4WK »
whats your tire pressure?
ponta2147
Post by ponta2147 »
I noticed that as well but chalked it up to being just a stiff ride overall, plus needing some time to be broken in. It's starting to loosen up a bit.
Kincaid
Post by Kincaid »
Maybe it's what you're used to? My '09 2.4L doesn't feel hard at all - it soaks up those large speed bump things and glides over railroad crossings. Of course, the pavement might be smoother out here is well. We get little in the way of potholes and frost heaves.
